swing arm bushing
Old Feb 15, 2015 | 01:42 PM
burleyburl1's Avatar
burleyburl1
Default swing arm bushing
I have a 2001 road king that I purchased a progressive stabilizer for .I jacked her up leaving a little pressure on the rear wheel ,removed the plate where it mounts and found the swing arm bushing I poor condition .my question is are there two and do I need to remove the bolt to replace the bushing and what other parts (shims spacers ect may I need) also what are the best bushings . thanks burl
Old Feb 15, 2015 | 03:00 PM
Musician's Avatar
Musician
The most common answer I see to questions like this is "Have you checked your manual?" If not, why not? It has pretty comprehensive information on all you will need, as well as being handy for repairs and maintenance.Good luck, but beg, borrow, or buy a manual for your bike.
Old Feb 15, 2015 | 03:08 PM
Jackie Paper's Avatar
Jackie Paper
Do http://partsfinder.onlinemicrofiche....HOCK-ABSORBERS.. You will probably have to do you year and model again. Do Harley OEM part finder. then year and model.. Pick Frame swing arm and jiffy stand in the fish
Old Feb 15, 2015 | 03:09 PM
Stiggy's Avatar
Stiggy
Yes, and the nut will only come off one side, the other being welded onto the shaft and that needs to be pulled on order to remove and install the swingarm bushings. The stock bushings are fine. Its the clevis blocks that are the weak spot. I chose to install Nylatron bushings while I was in there. That made for a huge improvement in swingarm stability with not much effect on vibration either.
Old Feb 16, 2015 | 03:31 PM
grbrown's Avatar
grbrown
There are two bushings, one each side of the swingarm pivot. Take a look at one of the on-line parts websites, like this one, where you will find a diagram of every part involved.
Be aware that the swingarm pivot also supports the rear of the trans/engine unit and that axle cannot be removed, to swap swingarm bearings, without supporting the trans. It is not a task you should tackle until you have studied what is involved! The trans/engine unit weighs at least half the weight of the bike.
SnoRider
Feb 25, 2016 11:50 AM
jmn1960
Aug 8, 2015 05:14 AM
foxtrapper
Apr 7, 2013 09:26 AM
lenny
Aug 30, 2011 11:32 AM
Smuggler07
Oct 26, 2010 06:18 AM
