clutch adjustment question
Hi all, 2000 flhtpi....50000 miles how do you loosen the lock nut on the shaft? I have the manual but it says nothing about that.I've loosened the cable and everything but i cant get the locknut loose, the motor turns over,even in first gear,...do I need to get a "locking" tool or something???
Thanks in advance, Mike
Once you get the adjustment made, don't over tighten the nut. Hopefully the videos or the stickies will give the tightening torque. It is pretty light, something like 120 INCH pounds, though I always check my manual as I don't trust my memory. Sounds like somebody waay over did it the last time and that plate will strip if the nut is over tightened.
Received 2,524 Likes
