When do you change the spark plugs ???
Old 04-19-2015, 10:50 PM
acchd's Avatar
acchd
acchd is offline
My manual says to inspect them every 5k and replace 20k which I do. Here's a handy cross reference.
http://www.harley-performance.com/ha...park-plug.html
Old 04-20-2015, 09:20 AM
SafetyMan's Avatar
SafetyMan
SafetyMan is offline
Originally Posted by gomiller2
Who in the hell would leave there plugs in for 100k really and why bother cleaning or changing the air filter ether and don't check the air pressure in the tires why bother it takes up way to much time.
That's asinine.
Not even any comparison. Period.
When was the last time a spark plug failed?
I'm not against changing them every 20k... 10k... 5k... it's a $12 / 5 minute job....
....but tell me the last time you heard of a spark plug failing.
A clogged air filter absolutely robs performance.
A flat tire... you may be the guy I have to explain that one to, but for now, I won't.
Old 04-20-2015, 09:36 AM
lp's Avatar
lp
lp is online now
Received 2,756 Likes on 1,565 Posts
Does every thread here need to turn into a "you're stupider than me" thing?
Old 04-20-2015, 09:40 AM
AZdryheat's Avatar
AZdryheat
AZdryheat is offline
I just installed NGK Iridium plugs and don't plan to ever change them. Supposedly they're good for 100,000 miles, which means they'll outlast me. lol
Old 04-20-2015, 09:58 AM
Glenn1911's Avatar
Glenn1911
Glenn1911 is offline
Just did mine at 18K and they still looked great but were not tight.
Old 04-20-2015, 10:03 AM
mouser58's Avatar
mouser58
mouser58 is offline
I had a set of factory plugs go out at 13,000 miles on my Road King.. I just turned 16,000 on my Road Glide and installed Iridium plugs and 10.4 MM Wires...
Old 04-20-2015, 11:02 AM
shooter5074's Avatar
shooter5074
shooter5074 is offline
Location: Western Illinois, land of bad roads, and corrupt politicians
Whether you change them or not, you need to pull them out and inspect them. Not so much to see if the plug is OK, but to make sure you can actually pull them. Aluminum and steel don't like touching, and over time will seize. So you need to pull them once in a while, and put a dab of copper anti-seize on them.
And I give a +1 to LP's question.
Old 04-20-2015, 12:22 PM
Dguy's Avatar
Dguy
Dguy is offline
Originally Posted by SafetyMan
That's asinine.
I think you missed the sarcasm in his post.
Old 04-20-2015, 12:32 PM
SafetyMan's Avatar
SafetyMan
Everyone missed the sarcasm in mine.
Old 04-20-2015, 12:38 PM
ndnguyd's Avatar
ndnguyd
ndnguyd is offline
But what about the pulstar plugs? lol
Quick Reply: When do you change the spark plugs ???
