Battery question
Old Apr 29, 2015 | 06:43 PM
kbberti's Avatar
kbberti
4th Gear
Smile Battery question
Hey everyone, I have a 11' road glide custom and I am looking to upgrade the soundsystem. Do I or should I upgrade to a hi-capicity battery or will the oem battery do fine? I am running a new head unit and putting in an amp pushing no more than 300 watts. I found this place http://antigravitybatteries.com
any thoughts?
Old Apr 29, 2015 | 06:49 PM
SafetyMan's Avatar
SafetyMan
Originally Posted by kbberti
I have a 11' road glide custom....
Tall, or long?
Huge either way....
My neighbor runs a big system on his '08, stock battery. The one that came when new....
It's almost 8 years old.
Old Apr 29, 2015 | 07:05 PM
TriGeezer's Avatar
TriGeezer
As long as you are not planning to play the stereo for extended periods with the motor off, or just idling, and as long you shut off the stereo before starting the bike you should be ok as long as your battery is healthy. Once you get the bike started it really just runs everything off the alternator. Otherwise if your alternator can't keep up, it would eventually drain the battery. So, as long as the alternator puts out enough power (DC Amps out of the regulator) you will be ok.
Simple math assuming 80% efficiency if the volume was cranked to the max 300 watts...the stereo would draw about 30AMPs...so you'll be ok unless you are running the air conditioning, all the lights, using the cigar lighter, using heated vests and gloves. Then you'll need a higher capacity alternator...ok...fine Stator..
Old Apr 30, 2015 | 12:11 AM
FlaHeatWave's Avatar
FlaHeatWave
If you use an efficient amp ie. Class D, the stock Harley electrical system will be fine.
Rauzer
Aug 11, 2012 05:15 AM
RidemyEVO
Mar 31, 2011 06:55 AM
Billy Blaze
Feb 5, 2011 12:07 PM
jeff.georgalas
Aug 26, 2010 07:09 PM
whwr55
Mar 20, 2009 06:30 PM
