Oh, and yes it will
Thing are slowing down just a bit now so I will be getting a little time to myself. I have my new trees sitting within 5 feet of my S&S 124CI bagger waiting for them to go on. With my trees, I can put in 41mm, the new 43mm Ohlins fully adjustable conventional forks, inverted forks both my KYB & Ohlins, and 49mm HD forks.
I am working on a full floating 320mm rotor wheel mount (Dyna's & 2014/2015 FLT) and also (std) hub mount which I have always had along with adapters to mount either the OEM HD Brembo or either the twin or four pad 65mm Brembos that I used previously, your choice. I need a broken/crashed 2014/15 FLT wheel for this project. I plan on expanding into the HD market more so than before. 2014/15 Spoke/wheel mount rotor also Dyna's https://cimg6.ibsrv.net/gimg/www.hdf...9918bcfcfb.jpg I do not make rotors smaller or remove them, I make them bigger so they stop better. |
Customer Service
HTML Code:
[QUOTE=hattitude;14103634 From your posts I can tell you are a technical person and a straight shooter. I would value your opinion/experience with the Ohlin/CCE mod....:icon_doh:[/QUOTE] In this life there are some who are exemplary citizens & if I can, I will do my best to facilitate some happiness in their life. GB will let the BS stop at the door. There are so many people here who are giving bad advice or reviews on products that they know nothing about, GB is refreshing in that he actually knows what he is talking about. I know 100% the Gent is not going to paint the experience with a broad brush dipped in BS. The truth has a tendency to come out in the end. Anyone remember Marc Parns & Mud? Perfect example of such a situation, too bad so many people got taken in with their BS. Good luck in this project GB. :icon_user: |
1 Attachment(s)
I was asleep while you chaps were chatting! Thanks for all the compliments and patience. I worked in the British defence industry (we spell that differently as well!) for much of my life, even with US defense contractors. So while I'm an engineer, my skills and home workshop facilities are limited, but I have a circle of friends and family with the expertise I need for some of the more adventurous work I do (relative to my skills!).
I'm building an entirely fresh set of forks and some of the H-D components I needed have only arrived since I received Howard's package of cartridges, hence some of the delay in making a start. My pal and I checked over the kit of Ohlins/CCE/H-D parts that I have assembled and reviewed the Ohlins instructions on Tuesday and, as soon as he has cleared his bench, we'll be on the case to assemble the fork legs. He's a retired Harley mechanic (do they ever actually retire?!) so between us we expect to be a brief blur of activity, to complete the first stage of this project! The job after that will be sorting out my '10 SG front wheel and speedo drive/spacers, before changing the top tree for the CCE billet one, along with new steering head bearings, after which the ole lady will be back on her wheels, with her 'new' baby blue front fender. No pressure then! :o |
grbrown you have had your cce top trees for a while that alone will be a big improvement. I contacted Howard about getting a set and he is waiting for your approval of the cartridges before he will release them to the rest of us. nudge!!!:)
No hurry grbrown just wondering how big and how much stuff needs cleaned off your friends bench!! this would be a good xmas present for me:icon_teeth:
I just got finished installing the CCE top tree with Ohlins FKC101 cartridges on my 2009 CVO Road Glide and it is a completely different bike as a result. I highly recommend this combination. CCE now offers the necessary top bolts to allow the use of the Ohlins cartridges with their longer fork tubes so the install could not be easier.
Originally Posted by Consig64
(Post 14129282)
(Post 14129282)
Originally Posted by sanman4ever
(Post 14134642)
What's the degree of difficulty for the install? Any special tools needed?
Setting the bearings in the neck just requires some patience but it is all explained in the manual. Enjoy! The results are worth it. |
Originally Posted by skypilot_one
(Post 14152400)
Where did you purchase the Ohlins cartridges?
http://www.propilotsuspension.com/ |
© 2024 MH Sub I, LLC dba Internet Brands
