rear bumper removal
rear bumper removal
On my `07 the rear bumper appeared to be supporting the fender.
Does the bumper support the fender on this `12 or can it just be
removed? I don't mind the chrome rail,but I hate the rubber.Can
the rubber be removed & leave the bumper?I've got to do either
one I can.That rubber has got to go.
On your '07 that bumper was attached to the saddlebag mounts and only had a single bolt through the fender. You can see the details for your current bike on-line here, which may help you remove your bumper. The rubber part was detachable from your '07, leaving the chrome tubes behind.
After laying my old butt in the floor I saw how it all
went together.Found out the rubber just pushes out.
I didn't like the look so I cleaned it real good & put it
back in.What I hated the most were those ugly torx
galvanized bolts.I bought some SS button heads & some
SS trim washers.Polished them up & put them in.Looks
better now so I guess I can live with the bumper for a
while longer.I hate galvanized bolts
Then I decided I didn't like the chrome fender tip light.
I'm kinda obsessive when it comes to vehicle mods. I was just gonna get bag fillers, then it turned into what you see above. Oh well. I worked a ton of overtime and felt I deserved something nice.
You guys removing your bumper need to buy the hidden brace. It ties together both bags and the rear fender and is pretty invisible. I researched this and read posts on other forums about guys that messed up their bags and bag mounts because they didn't install the brace. It was pretty cheap, under $50 I believe. Sorry I don't remember how I found the part number, picked it up in a post somewhere.
http://partsfinder.onlinemicrofiche....DER%20-%20REAR
#33 saddlebag support to fender bracket. Comes stock.
