Ok, here is one for ya
"Parade Mode". Was told when sitting in traffic and engine running the motor will go into Parade Mode. Meaning that it will only run on one cylinder and will go back to both if you twist the throttle. Or you can put into Parade Mode by rolling the throttle forward.
Ok here is the problem. Sometimes after shutting the bike off and restarting it will crank and crank and then run rough like its in Parade Mode but will NOT accelerate no matter how far or how many times you roll the throttle. I will then have to "reset" the bike by turning it on and off (not starting) three times or so and then start it. Usually it runs fine after that.
Mechanic that does all the work on my bike said he never heard of this happening and will have to research it. Anyone here have an idea?
Last weekend this happened to me as well. It was really hot and at a stop the bike went into the tem management mode, then when I took off from the stop, it just stayed on one cylinder. Stopped, shut off bike looked at everything I could think of, found nothing. Started it and it ran fine from then on.
