Bike Died and Won't Start
Here we go again......
2005 FHLTCI. New battery 6 months ago. At a stop light in the commute on the way home. Lay into the throttle, bike dies, maybe a little pop.
Pulled into a parking lot nearby. ALL systems seem to work except starter and fuel. I hear a single click when turning ignition to on but NOTHING when hitting the starter button. No fuel pump. No starter solenoid, etc.
Was going to start with EFI Relay and Fuses.....
Todd,
Sounds like one of your neutral switch leads was off.
Charge the battery and see if it holds a charge. 12.7 and above is fully charged, 12.6 75%, 12.3 50%, 12.0 25% and 11.8 0%. Take it to a parts store and have them do a load test. If the battery is bad you should test the charging system.
A bad battery can show 12+ Volts after being charged but drop significantly when a load is applied.
I may try that in a few. Either way shouldn't the Power Commander light up if Ignition and Run switch are both on?
