PC3 MAP for V&H TURN-DOWNS & SE AIR FILTER
I am due to have a PCIII USB arrive any moment for installation on my 2000 Ultra. I can't seem to find a map on the Power Commander website for my stuff. I have a Screaming Eagle a/f with Vance & Hines turndown slip ons. Will the map for the Vance & Hines Ovals be close?
One more question - how do I know if the previous owner installed theStage One flash or if I still have thestock ECU? Thanks for your help.
RE: PC3 MAP for V&H TURN-DOWNS & SE AIR FILTER
Only way to tell if ecm has been flashed for stage 1 is to have the dealer check it, but if it already had slipons and the se air cleaner it probily has, if it was stock when you got it it probily doesn't. The PCIII map that would be closer than the oval one would be M802-302 for stock ecm or M802-303 for ecm with stage 1 reflash. Ovals are not as free flowing as turndowns but the slash cuts are very close to the same flow rate.
