Whats the MAP???
Old Aug 16, 2007 | 04:44 PM
Streetmed's Avatar
Streetmed
Default Whats the MAP???
Anyone know which MAP I should use for the following upgrade on my PCIII:
K&N stage 1
V&H True Dual Big Shots
I think I have found it on the power commander website I just want to make sure I am right, thanks for the help!
Streetmed
06" Streetglide
Upper Darby PA
Old Aug 16, 2007 | 06:20 PM
glens's Avatar
glens
Default RE: Whats the MAP???
Code:
M812-016.djm
 *Advanced Map*
 Vance & Hines Big Shot Duals
 Screamin' Eagle air filter
 Stock ECM
 Dynojet O2 sensor eliminators installed
Unless they've got something newer that should be the one. The air cleaner isn't going to be enough different to worry about. So long as you don't have the "Stage 1" download from HD it should work like a charm.
Old Aug 17, 2007 | 09:44 AM
Streetmed's Avatar
Streetmed
Thanks Glen, appreciate the help and ride safe.
Streetmed
06 Streetglide
Upper Darby PA
Navitimer
Oct 21, 2007 09:09 AM
robbitybob
May 2, 2007 03:36 PM
rideon
Dec 3, 2006 07:29 PM
dale51racing
Sep 19, 2006 08:23 PM
mhughes600
May 16, 2006 06:32 PM
