recommend a pcIII map please
Old May 15, 2006 | 02:33 PM
mhughes600's Avatar
mhughes600
Default recommend a pcIII map please
I put a pcIII on my 04 standard along with a stage 1 ness big sucker and rinehart 2 into 1 pipes.
anybody with similar setup? thanks
Old May 15, 2006 | 06:38 PM
FreddyP's Avatar
FreddyP
Default RE: recommend a pcIII map please
I'd recommend a custom MAP from a good dyno shop....but if that isn't possible you might consider:
M807-125 for Bub Rineharts, Stage 1 ECU and Screamin Eagle air filter
M807-176 - 05 Model, Rinehart True Dual exhaust, Stage 1 ECU and Screamin Eagle air filter
Not sure if either one is really a good match for your setup. Might try searching through the detailed description for the MAPs (Stock ECM, Stage 1 ECM and Stage 2 ECM) on the Power Commander web site at http://www.powercommander.com and see if there is a better match. (Assuming you haven't done this already).
Old May 16, 2006 | 06:32 PM
mhughes600's Avatar
mhughes600
thaks for the help, i'm still looking around but i'm sure i will find something.
2008FLHP
Dec 1, 2007 05:13 PM
Streetmed
Aug 17, 2007 09:44 AM
Smurfshxt
Jul 5, 2007 03:28 PM
rideon
Dec 3, 2006 07:29 PM
