air shocks wont hold air
So since I have yet to put a gauge on my shocks yet, I was at the dealership last night and asked if I could borrow the air pump and check the pressure.
hooked the pump up and saw that there was basically 0 pressure. A few pumps and the needle went up, but air leaked right back out.
So I am going to remove the seat tonight and try and follow the air lines to see if I can see a leak or possibly a disconnection. Anything else I need to look for or be aware of?
Well, Everything I have been reading on this forum all points to these shocks being junk. I too have original air shocks and they will leak down over a couple days. I bought my bike from a dealer and it is going in Sat for warped front rotors and brake pads under the 30 day warranty. I might mention my shock problem and see if they replace them or I might just upgrade to a better shock.
You can try brushing some soapy water at all the connections and see if you can spot a leak. I had a small leak in a line at the elbow fitting that wouldn't show up with the soapy water. I pulled the tubes out and re-cut the ends of the air lines with a razor blade and reinstalled and no more leaks. Also check the valve for leaks.
If you're dead set on keeping the single fill point, check all connections with soapy water. When you find the leak, trim the line above the kink put a dab of vaseline on the end of the line before reassembling.
I found this to be very normal as well. Plus even at 50 pounds they are not very good for two-up as people stated. I installed a pair of progressive 444's and it way better. Bit of a hassle to remove the bags to adjust for two-up so generally I just leave them adjusted for that unless I am going on a long ride solo.
Received 2,525 Likes
