Shifter Linkage Came Apart
Changing to Heim is the best solution. Because it is a weak setup I picked up a spare stock rod before a trip which has been buried in my saddlebag for years for whoever needs it on the road. The washers and nuts were not included and purchased separately. $23 is cheap insurance.
Your is the first report I have seen of the nut coming off. The more frequent failure is the ball falling out of the socket. The heim joints eliminate that failure possibility but they also mount with nuts and bolts which can come loose or fall off. I just lubed my heim joints after about 4 years in use. I turned the ball 90 degrees and squeezed some water proof grease into the race part of the heim joint. They needed it. The ball coming out of the socket begins to happen at about 25,000 miles. Above that mileage you are on borrowed time with the factory ball joints.
Received 1,506 Likes
Originally Posted by Hausguy
Going over the critical fasteners doesn't take very long and you (the owner) will be more thorough than the dealer.
