Sound system help?? 2015 SGS Amp & Speakers
I need some help trying to find the right system for my Street Glide Special. There are so many options but I'm looking for others that have the perfect combo: speakers + amp= loud & clear.
At first I wanted just to replace the 2 fairing 6.5's but I want to leave room to expand to either lid speakers or pods. So I want to hear what you guys are running for power, 4 channel amp and what speakers you chose to add for the perfect combo! I'm doing all my research based on your reviews and input so please help me out. I'm looking for clarity with volume, tight lows, crisp highs. I'm also trying to not spend crazy money or I would consider the Focals because I hear really good things about this brand. Tell me what you have, how much you put into it, and about install. I know about the flash but I will buy a magic box because I have the Boom 6.5 head unit and plan on keeping it. I appreciate any input, opinions, and advice. 🙏🏽
You may get better feed back in the audio section.... I would copy and past your questions there.
If you do not know how, highlight forum on the top of the page hover over tech/mechanical then you will see audio...
Some amazing help over there, most have tried everything, to give real world, hands on advice.
Thank you Hunter
Line levelers from Biketronics work better than the magic box on the Rushmores, Biketronics sells a plug and play package, you can get their 4 channel amp, line levelers, speaker brackets to replace the pods, and speakers. That would give you the option to expand to your lid speakers when your ready. Life time warranty also.
What ever amp and speakers you go with, I would still consider the line levelers over the magic box, and the speaker brackets.
No flash needed with the line levelers, unless you want the fade option once you install the lid or lower speakers...
Angelsbass, how much are you looking to spend? This will help out with suggestions.
I'm currently running a Rockford TM400X2AD to Arc Audio Moto 602 speakers along with the BT355. I drilled 3" holes in the back of my pods to get some air moving. Sounds pretty good and should only get better once I get my lids running with the Moto 6x9's.
No dealer flash needed with my setup (aside from having the stock Ultra flash to enable the rear speaker channel and allow fader option)
