Cam chain tensioner upgrade problem
Old 06-09-2016, 02:56 AM
GJSchultz's Avatar
GJSchultz
GJSchultz is offline
3rd Gear
Default Cam chain tensioner upgrade problem
Hello all, bikes a 99 Road King 30k miles. I'm installing the Screaming Eagle cam plate upgrade. When plate is installed rear cam can slide in and out about 1/4 inch. Original outer bearings were both press fit bearings, front bearing was installed with numbers in and very wobbly, rear seemed ok. New bearings, front is press fit ball, and rear is two piece roller bearing, cam chain seems to be the thing that keeps cam in place. I have done searches on issue with no luck.
Thanks.
Old 06-09-2016, 05:02 AM
foxtrapper's Avatar
foxtrapper
foxtrapper is online now
Received 1,257 Likes on 818 Posts
Mmm hmm. Sometimes the cam can slide out quite easily when it's just sitting there in the cam plate. Mounted in the bike, it's not coming out because of the bearing in the engine. But sitting there in the plate, the chain is indeed the only thing holding it in.
Old 06-09-2016, 05:15 AM
lp's Avatar
lp
lp is online now
Received 2,726 Likes on 1,550 Posts
For 99-06 the outer bearings are pressed into the cam plate.
The cams are then pressed into those cam plate bearings.
There could be a little bearing side play and wobble, but the cam shouldn't just slide out of the bearing after it's been pressed in.
07 and above there are no longer any press fit bearings in the cam plate.
Old 06-09-2016, 05:33 AM
GJSchultz's Avatar
GJSchultz
3rd Gear
The rear bearing in the kit is a two piece bearing, the inner race presses onto the cam and the outer race with the rollers presses into the support plate. When front cam is being pressed into front bearing rear cam just slides into position. When rear chain sprocket is bolted on with its spacer cam will slide in and out making it impossible to check with feeler gauge for sprocket alignment.
Thanks.
Old 06-09-2016, 02:35 PM
GJSchultz's Avatar
GJSchultz
3rd Gear
bump.
Old 06-09-2016, 02:46 PM
xcbullet's Avatar
xcbullet
xcbullet is offline
I did this get last year isn't there spacer kit you need to buy in the papers. Also the 99 needs a plug that goes in one of the lower holes.
In pic right side of bag on top I think those are it.
Attached Thumbnails Cam chain tensioner upgrade problem-img_20151002_174807229.jpg
skrody
Engine Mechanical Topics
06-01-2015 04:19 PM
micalaut
Exhaust System Topics
04-09-2013 05:57 PM
MarkM
06-10-2009 05:25 PM
bigdaddysdaddy
General Topics/Tech Tips
02-14-2009 10:11 PM
Groundhog
11-29-2007 07:12 AM
Quick Reply: Cam chain tensioner upgrade problem
