Cam Bearing install TC
Old Nov 30, 2008 | 10:53 PM
bigdaddysdaddy's Avatar
bigdaddysdaddy
Default Cam Bearing install TC
No need to go out, and buy "special" bearing installers for the cam bearings. To install the bearings in the cam plate simply place bearings in the freezer for about 30 min. and the cam plate in the oven for same on 350 degrees. The bearings will just slip right in, no headaches.
Old Dec 22, 2008 | 11:11 AM
mopardave's Avatar
mopardave
How did you get the old bearings out? Big hammer? LOL
Old Feb 14, 2009 | 10:01 PM
KumaRide's Avatar
KumaRide
If your cam plate has one, my 06 did not, first remove plug and oring at top of cam plate (look in manual). Heat cam plate assembly, including cam and bearings..., for 15-20 minutes minutes at 350 and they fall out or may require a very light tap or two. Use a socket the size of the bearings and a rubber mallet to tap them out.
Old Feb 14, 2009 | 10:11 PM
CL's Avatar
CL
Coitenly,
biddaddysdaddy
Iman01
Engine Mechanical Topics
Dec 15, 2025 11:34 AM
Iron lHorse
Dec 18, 2013 09:13 PM
micalaut
Exhaust System Topics
Apr 9, 2013 05:57 PM
Mullenix53
Mar 12, 2008 07:02 AM
JimTJr
21
Oct 18, 2007 07:56 AM
