SAE 50
Old May 21, 2007 | 12:03 AM
Phins74's Avatar
Phins74
Default SAE 50
The sevice manual states that if your ambient temperature does not go below 60 you should or could use SAE 50 oil. Has anyone in the hot climates used this oil. Im thinking Florida for the next few months may be ideal and quiet down the top end of the motor as well. any thoughts?
Old May 21, 2007 | 12:55 AM
DelawareDon's Avatar
DelawareDon
Default RE: SAE 50
I'd rather be using Amsoil or Mobil 1.
Old May 21, 2007 | 01:00 AM
ZD's Avatar
ZD
Default RE: SAE 50
20W-50 will give you exactly the samehigh-temperature protection as straight 50 weight, with higher oil flow during cold starts. (If there is any such thing in Florida this time of year!) In my view, there is no reason to use straight 50W for modern engines.
Old May 21, 2007 | 01:15 AM
Bryan1724's Avatar
Bryan1724
Default RE: SAE 50
IMO SAE 50 is just too Damn hard on the motor, it has to work so hard to push it through the lifters, push rods etc.Maybe if the oil was 100 degrees when you cranked the motor up (lived in the desert)but that stuff is just too thick. Would do more harm than good on start ups. Just my thoughts.
Old May 21, 2007 | 01:33 AM
SoCal_Pappy's Avatar
SoCal_Pappy
Default RE: SAE 50
I live in Palm Springs, CA... Summer Temp here 126+ at times... Use Amsoil - Mobil 1 - You'll be better off!!
fmlawn
Oil Archive (no new posts)
Nov 12, 2014 08:19 PM
Buckinfitch
Sep 21, 2013 08:17 PM
Pango40
Sep 30, 2012 01:11 PM
the4thgearkid
Aug 4, 2009 08:19 PM
GAstreetglide
Jun 26, 2007 04:47 PM
