Primary and Transmission oil
Looking for a bit of advice. All you guys/gals have been really helpful to me so far and I can't thank you all enough!
I want to change out the primary and transmission oil on my '07 Electra Glide UC.
First off, my BIL, who has been working on HDs his entire life(I think he was born with a Harley Davidson birthmark somewhere on him, but I digress). He swears by Amsoil 20W50 synth. He tells me it's ok to use it as primary oil and transmission oil. I don't want to second guess or disagree with him, but I'd like some opinions.
What do you guys think?
ElectraJim (08-18-2016)
Is that GEAR OIL in the primary? Might want to check the ingredients to see if any are hard on copper electrical windings
yes, you can use it in your primary. but why? it is way too expensive to use, it's overkill.
my recipe?
primary: shell rotella t 10w-40 ($15.00 per gal), change at 5k interval. along with clutch adjustment, unless you have a hydraulic clutch, no adj. necessary.
transmission: whatever gear oil is on sale. change at rec. 20k interval. currently running supertech synthetic 75-90. yes, that's walmart oil. it's mfg by citgo. if you read bobistheoilguy.com you'll see that it has good used oil analysis on it.
my recipe?
