Primary seal repair + 34T trans sprocket and new belt... QUESTIONS
Need to pull the primary so I can repair an oil leak, not exactly sure where it is, or what seals could be involved. I thought my primary outer gasket was leaking, however, I am pretty sure it is not the outer primary gasket. I changed the gasket, and without any fluid in the primary, I could see an oil leak in the same spot under the bike.
1. I'm thinking it's the trans seal, but I'm not sure. Looked through the manual and could not tell if I can replace the seal when the primary is removed.
2. Also thinking I will change the belt, because it has a hole from a rock in it.
3. And, I would like to change to a 34T transmission sprocket to drop the revs at cruise. I have read that I can still use the stock 139T belt - just was hoping to confirm from those that have done this.
4. What else should I consider doing while I have the primary off?
Thanks for helping!
Thanks for helping!
Did you check to see if it is the seal around the gear shifter?
Since you will have the primary off change it anyway if it's not leaking (easy fix). Also might think about changing the inner primary bearing since your gonna be in there. Good time to look over the compensator and check your primary chain tension shoe for wear.
See if this gives you any help man.
Take that with a handful of salt! I went the other way recently and swapped to a 30T pulley and have read that also can be done while still using the stock belt. Not on my bike! I had to buy a new shorter one. Wait until you have your bike apart and can offer your belt up, but do that with your damaged belt before buying a new one!
Going to try a 34T trans sprocket and was hoping to see if there was an alternate belt if my 139T doesn't fit.
Anyone have an alternate belt size/part number?
Part Number Teeth Width Application Spare
40001-85 136 1.5" 32x70 Touring 40100-85
40003-79 126 1.5" 32x70 Touring & Dyna 40101-80
40012-90 128 1.5" 32x61 Softail
40015-00 133 1.125" 32x70 Dyna 40109-86
40015-90 133 1.5" 32x70 Touring & Dyna
40017-94 130 1.5" 32x65 Softail 40171-97
40022-91 128 1.125" 27x61 XL
40023-86 132 1.5" 32x70 Softail 40109-86
40024-04 139 1.125" 32x70 Touring 40112-97
40024-07 137 1" 32x66 Touring
40024-97 139 1.5" 32x70 Touring
40027-01 150 1.125" 30x72 VRod
40040-05 139 32x70 CVO
40046-07 131 1" 32x70 Dyna
40048-07 130 1" 32x64 Dyna Japan
40056-07 136 1" 32x64 Touring Japan
40058-07 133 1" 32x66 Softail
40073-07 133 20mm 32x66 Softail
40074-07 132 20mm 32x64 Softail Japan
40105-01 149 28x72 VRod
40105-04 149 1.125" 28x72 VRod
40113-97 Spliced
40118-05 149
40119-05 150
40130-03 139 32x70 CVO Heavy Duty
40144-07 151 1.125" 28x72 VRod
40145-07 152 1" 28x72 VRod
40307-00 135 1.125" 32x70 Softail 40146-00
40371-07 136 28x68 XL
40591-07 137 30x68 XL
40627-06 149 28x72 VRod
40655-06 135 20mm 32x70 Softail
40658-06 150 30x72 VRod HDI
40113-97 Spliced
40118-05 149
40119-05 150
