Need help swapping rear rim
I have one in my 1990 Glide. It is not what I will call a bolt-in, more a shoe-in! It can be done, but if you have to ask......
I have an Avon Venom 160/70 in mine, which is actually measured at 167mm wide. I also have a rear fender which fits dead centre in the frame, so clearance each side is equal, but very close. I use a 1 1/8" belt, which is darned close to the rear tyre. If you use non-stock pulley and rotor, as I have, you will need to use a blanking disc (stock Harley part) each side, to close off the holes to the centre of the wheel (to keep water out).
I understand early CVO models used a similar wide wheel and also a wider rear fender. I shopped for ages looking for one but was never successful, hence I use a stock one. Certainly a wider fender would make life easier, however clearance between tyre and belt is darned close.
