200mm deuce ??
Old May 4, 2010 | 02:27 PM
deuce06's Avatar
deuce06
Default 200mm deuce ??
I have a 06 deuce with stock 17 x 4.5 chrome rear wheel. I have a pro one sinnister wheel on the front with matching pulley and rotors. I'm wanting to upgrade to a matching sinnister rear wheel and a 200 tire. What size wheel and what other things do I need to accomplish this? I'm wanting to keep the pro one pulley that matches my wheels. Please be specific. Just wider rim, tire, and what else??
Thanks for the help
Old May 4, 2010 | 03:13 PM
Hollywood Ball's Avatar
Hollywood Ball
probably custom spacers... there is a very detailed deuce 200mm conversion thread that someone did. Pics and detailed instructions. the whole 9. I don't feel like searching for it, but it's here somewhere...
Old May 4, 2010 | 04:47 PM
flibuoy's Avatar
flibuoy
I second the do a search suggestion. I have an '05 and put a 170 Metzler on it because of all the conflicting information on ease of 200 swap. I don't think the front tire/rim needs to be considered but thanks for including. I suspect that the rear rim may influence your swap since the stock width Deuce seems to only need spacers...but then again info is conflicting and your rim will probably impact the installation...sprocket? belt? Wish I could help other than suggest a search and MAYBE you'll find good info. Have you looked in tires/wheels section of this forum? Maybe ask there AFTER your search. John
Old May 4, 2010 | 06:53 PM
mac0478's Avatar
mac0478
I have been wondering about the same as I will be the proud owner of an 03 by the end of the week....now where is that thread?
Old May 5, 2010 | 04:58 AM
kiwideuce's Avatar
kiwideuce
you need an 18 x5.5 wheel!! you can run a 180 with no mods, thats what i have on at the moment!
to go to a 200,all you need apart from the 18x5.5, is the narrower 7/8" belt and pulley!
the original 1 1/8" belt will clear a 180 safely, a 200 needs the narrower belt!
jd8181
May 15, 2021 08:38 PM
kidn1980
Oct 30, 2016 12:22 PM
white01ss
Jul 26, 2013 12:11 PM
HDnoob
Softail Parts
Jul 9, 2012 08:59 PM
deuce06
Feb 25, 2010 01:39 PM
