Inner Cam Bearing Remover/Installer Tool
RE: Inner Cam Bearing Remover/Installer Tool
Cam Tools:___DepositDonation
-Zipper’s® Twin Cam Relief Tool – Zippers® 713-905200.00 30.00
-Inner Cam Bearing Remover/Installer - JIMS® 1279/1278200.0030.00
-Cam Bearing Puller – (pulls bearing from front cam) - JIMS® 1280 125.00 10.00
-Cam Shaft/Outer Cam Bearing Remover/Installer - JIMS® 1277100.0015.00
-Cam/Crank Sprocket Lock - JIMS® 128530.002.50
-Cam Chain Tensioner Unloader - JIMS® 1283 30.002.50
-Oil Pump Alignment Tools for Stock (2) - JIMS® 33443-820.002.50
-Oil Pump Alignment Tools for Fueling Oil Pump (2) – Custom20.002.50
-Threadchasers (dies) (Rockers – 5/16x18NC, Crank bolt – 3/8x24NF) 20.002.50
-Hydraulic Lifter Holding Tools (wire clips)N/CN/C
Big Bore Tools:
-7/16 in. and 1/2 in. torque adapters (3/8 in. drive)35.005.00
-Wrist Pin Circlip Remover/Installer60.005.00
-Wrist Pin Remover Tool (Locally Fabricated, AKA “homemade”)20.003.00
- Piston ring compressor (T-Bolt Clamp)5.001.00
-1/4 in hex ball manifold wrench (short 90 deg bend) 5.001.00
Additional Items Available For Sale:
-Torrington® B-148 Inner Cam Bearings (2)10.00
-Torco® MPZ Assembly Lube 5.00 __________________________________________________ ____________________________
SCHEDULING:Contact me and give me a heads up ASAP with a proposed timeline for your project.
DEPOSIT:Please read carefully for your options!!!:
1.PayPal:I have two PayPal accounts, one that can take credit cards, and one that can’t.Decide on how you will fund your payment and I will give you the appropriate account address.
a. Instant Transfer (uses your PayPal Balance as your source of funds.)Preferred
b. Credit Card through PayPalAdd 3% of the deposit amount for PayPal credit card fee.)
c. eCheck (uses your bank account registered with PayPal as your source of funds.Generally takes 3-4 days to clear, with no additional charges).
2.MO or Cashier’s Check:Send to the address at the bottom of this page.
TERMS:
1.Minimum donation will be $30.00. Prices are subject to change.
2.I will return your deposit minus the donation, my actual shipping cost, and credit card fees (if applicable) when the tools are returned in good working order.You cover return shipping cost.
3.Tools need to be back to me 21 days after you receive them, or your requested arrival date, whichever is later.I reserve the right to charge $5.00/day late charge and consider them sold after 45 days in your possession.If you’re having problems, call me and we’ll work it out.
4.No guarantee/warranty expressed or implied.Use these tools at your own risk!!!
[i]I highly recommended that you have a factory manual for your model, a lift to get the rear wheel off the
Big Bore Tools:
TERMS:
maineultraclassic
08-29-2006 07:16 PM
