Hard starts and battery acting like it's dying
OK, I just want to get a little more advice. A couple of friends gave their opinions but I figured I'd ask the all knowing gurus here.
My battery died on me about 3 months ago so I shelled out $130 for a new one with a warranty. It was charged before it was put in my bike. That was about 3 months ago. Now my bike is having hard starts and sometimes won't start at all like the battery is dead. I checked the charging system and it's putting out 13.8v. With the bike off the battery reads 11.9v.
What's the deal? One friend said to replace the rectifier and stator. What's everyone's opinion on the problem and what steps should I take to track down the problem?
Thanks in advance,
Igor
Thanks in advance,
Igor
A good battery is at least 12.7, so your battery is in need of a full charge before you do anything. As for 13.8 charging, was that with the dead battery installed and what rpm was that reading taken at.
How often is the bike used, is it on a tender if it sits, has the bike been parked for the winter? We need more information before we can give you solid advise.
The following 2 users liked this post by Camarosx2:
sabunimwil@gmail.com (04-09-2017),
Tat2dMFr (06-23-2023)
I just replaced a battery. Load tested fine... but it would drop voltage over night. Shop said, it could have a cracked cell, that all though a load test is a great way to identify if a battery is good or bad, it's not always 100%. I came across this site when I was looking into mine. A lot of good info. Mine would drop from 12.75 to 12.25 over night... Again Load tested good... Not worth it to me to mess around with a battery.
http://www.dansmc.com/batteries.htm
Sounds like it might be the battery to me but I'm here for advice because I am just a beginner.
13.8 volts may be too of a charge voltage but a 1k rpm it's hard to say. The FSM says to check voltage at 2k rpm. It should be 14-14.2 volts at 2k rpm. I would reccomend getting the FSM as it has complete instructions to test the charging system including both the stator and voltage regulator.
In the meantime, check all of your connections, wiring and grounds. There are several grounds - in front of the battery and VR bolts are prime places to check.
Or you could just be unlucky and have gotten a dud battery.
sabunimwil@gmail.com (04-10-2017)
Received 4,312 Likes
The 13.8v sounds a bit weak, the charging is going right to the battery, I'd be doing a charging system test. A weak battery cold induce failure of a regulator/rectifier and work down to the stator over working. Keep the multimeter probes on the battery and take the rpm's up to 2K or slightly higher see if you get to 14.2-4v.
im just telling you what worked for me , i was using the junk Harley tender and my battery died got a new battery and then it died , replaced the tender with a much better one and it cane with a new pig tail for the tender to plug into. took old pigtail out and it had a short in it. been fine ever since
