To headlight lens
not sure i quite understand you question...
all the headlight reflectors from 1949 to today interchange....
the bulb may be a fit problem in the RK if you try an aftermarket LED type things as it stick out too far at the back.
if your is busted, the dual halogen is a nice upgrade and shows up used on the classifieds often- cheep.
minor wiring modification needed
mike
mike
