can someone give me instruction as how to change fork oil, seals, bushings & guides on my 09 Street glide?
Hey Everybody, I'm new to the forum, this is my first posting. I apologize in advance if I'm in the wrong forum and for it being too long. Here's my question. I live in Northern California and I'm a "fair" mechanic and have done some basic maintenance on my bike(s) in the past: oil changes, plugs, plug wires, starter, triple tree, air cleaner on my '04 Dyna Low Rider. 3 years ago I bought a 2009 Street Glide (with 20k miles) that someone put a lot of money into. (I have all the documentation as well) Between late 2009 to late 2010, the previous owner did the following: 106" S&S Engine, Cylinder Kit, Twin Cam Port & Polished 4 3/8 Flywheel, Pro Clutch Kit, Compression Release. Knight Prowler Cams, Evo Spring Kit, ThunderMax , 2-1 exhaust, Works Performance Steel Tracker 13' Shocks, Custom stereo, etc. I LOVE IT! Way more power than i'll ever need. I Didn't need to do anything but RIDE!
To date, I haven't had ANY problems with the bike. Last November I did my 25K service and put new tires on it. I dont ride nearly as much due to work, family, weather. Unless it's 68 degrees and clear skies, I dont ride. However, once the weather turns to late spring, I take my bike to work 3 out of 4 days a week.
A few weeks ago, I came home from work, after a 1/2, I went out to the garage and noticed a HUGE puddle on the front left side of the wheel of what I thought was brake fluid. I checked the master cylinder reservoir and it wasn't low. I looked at where the banjo bolt and brake line come in and thought that's where the leak was. I was short on cash and decided to wait till the first to replace the crush washers & banjo bolt. In the meantime I went to all the HD forums, you tube, etc researching this issue. About a week later, I started the bike warmed it up for 5 mins, pulled out of the driveway for 200 feet, turned around and parked it in the garage. Where there was plenty of light and no vehicles. inside of 5 mins, the bike started leaking again, but it wasn't from the front left caliper, banjo bolt, brake line area like I had thought, it was leaking from the left fork tube.
After researching the costs (anywhere from $450-$600) to have my forks serviced and kitted at a shop/dealer: they'll replace the seals, bushings, guides, washers and oil. The fork kits run about $45-$60 a side, + 2 pints of fork oil at $8 a pint. It's about $120 for parts. I feel fairly confident that I can complete this. Any suggestions or words of advice?
I really appreciate the posts in here. As most people are really helpful. Thanks again
Leak on 6-8-17
Leak on 6-8-17
Leak on 6-8-17
Leak on 6-8-17
Leak on 6-8-17
Leak on 6-8-17
Leak on 6-8-17
Leak on 6-8-17
This is the best video I've found on the subject. Overall it's a fairly easy job.
You may want to consider buying a seal driver instead of rigging some pvc, and I recommend placing a washer over the seal before you drive it home. That'll make sense to you when start putting it back together.
Ragtop (06-24-2017)
https://www.youtube.com/watch?v=vrmYJgcGX30
