Primary Chain Tension - stock tensioner - 2014 RK
Hey all -
I have a 14 Road King with 10K miles (yeah, I know...I need to ride more!). I do as much of my own maintenance/upgrades as possible on this and other bikes I've owned. I've done OK with a wrench and my Service Manuals so far...no screw-ups.
I recently changed engine and primary fluids. Everything looked normal. I use Formula+ in the primary and Mobil 1 Syn, 20-50 V-Twin (or M1 Syn, 15W50) in the motor.
Looking for some advice as to when I should remove the primary cover and check the primary chain tension(?). I was thinking of checking it at 15,000 miles when I do the next primary oil change. The bike is starting/running file at the moment. (BTW...$36 for the HD primary cover gasket! HD's over the top on their pricing!)
I read that the new automatic chain tensioners tend to leave the primary chain a bit too tight. Has that been the experience of most folks who do their own maintenance?
Looking for recommendations as to what mileage point I should pull the primary cover and check the chain tension(?).
If I find the primary chain is indeed too tight, should I consider replacing the stock tensioner with a Baker or Hayden? I sure did like the manual tensioner on my 04FatBoy...it worked just fine.
I would appreciate some recommendations from those with 2014 or similar set-ups who have more miles on the clock than I do.
Thanks all...
Regards
Thanks all...
Regards
u wish u could ride (06-18-2017)
OldMike (06-18-2017)
I've been unfortunate enough to have lost an IPB and a trans output bearing a time or two due to the auto-tensioner ratcheting up too tight.
If you start feeling something that feels like a rough bearing or constant hum/vibe that follows engine speed that's something you'd want to check for.
Usually gets worse as the engine heats up... (it's the chain tightening)
After using two different manual tensioners I finally just went back to using the auto-tensioner but used aircraft quality safety wire to loop it over and around the wedge/spring to lock it in place.
Now it has a little spring tension as it should but won't ratchet up unless I do it manually.
No issues so far in over 15,000 miles using this method. Cheap and effective.
The following 2 users liked this post by lp:
johnnynitro (06-18-2017),
telec68 (08-14-2021)
I really don't give much thought about my primary chain. I heard they can run tight but I've never had a problem.
