2015 greet glide front wheel question
Old 06-18-2017, 10:57 AM
Cadilacjoe's Avatar
Cadilacjoe
Cadilacjoe is offline
Default 2015 greet glide front wheel question
I have a wobble. U can kinda feel it at low speeds but at 86 she wobbles. So took the front wheel off. My question the spacer between the wheel bearings is that suppose to be loose. I checked my 2012 wheel and it's tight in there. Thanks
Old 06-18-2017, 12:47 PM
GTK's Avatar
GTK
GTK is offline
When new wheel bearings are installed,the right side is the last one and it is pressed in against that spacer so that it just touches it.So you should feel a slight movement in spacer.
Old 06-22-2017, 04:46 PM
Cadilacjoe's Avatar
Cadilacjoe
I put a rim and tire on from a 12 and I stilll have this wobble not as bad but still there. Guess I can only go 80 unless I buy another one.
Old 06-22-2017, 05:09 PM
lp's Avatar
lp
lp is offline
Received 2,722 Likes on 1,547 Posts
Try tightening the neck bearings. Pretty common issue.
Rtl4042
Wheels/Tires
06-20-2017 09:50 AM
Curtis36j
05-03-2016 04:10 AM
NightHunter
06-08-2014 02:34 PM
clarkchriston
04-09-2014 04:43 PM
skos
Wheels/Tires
03-27-2009 10:02 AM
Quick Reply: 2015 greet glide front wheel question
