Need help: docking system & stealth rack fitment
Im headed on my first road trip this coming Thursday on my 2011 Road King and have an issue.
I purchased a 4 point docking system off eBay and installed. Instructions were poor but I watched a video and its on right I believe.
I also purchased a stealth luggage rack off eBay. However, the width of the rack is not enough to latch into the docking unit. Which led me to believe the docking unit was not on correctly. So, I took it off and reattached (and stripped one hex screw while at it). But the rack still won't match up.
Has anyone had this issue?? Any issues with my mounting? Any tips to "make it work"?
It looks like the docking hardware is on right. Is it only the back part of the rack (your top photo) that is tight and the latches fit okay?
If so, you can use a wooden handscrew clamp to 'spread' that part of the rack to fit. A buddy has a 12 King that had the same issue with his rack and that is what he did to make it fit.
RKGD (08-25-2017)
Neither points match up right now, width wise. I will get ahold of a clamp and try your suggestion. Thanks!
