Another Wheel bearing thread
I recently read a piece in one the the motorcycle mags, they were talking about wheel bearing failures/replacements. They said to never spray a pressure washer/car wash wand on the sealed wheel bearings. The water will enter the bearings. And we all know what happen to a bearing when water gets into the grease. Had a boat for years. Backing the trailer in and out of the water always gave the problems with the bearings.
http://www.georges-garage.com/index.html
Standard disclaimer:
I have no affiliation with this company. Just a satisfied user of the products.
Received 4,614 Likes
I've done several bearings with the Pit Posse, and some were really tight. Handled them with no problems. But like I said before, grease everything on the tool that rubs other metal, and I'd grease the threads on a version with the bearing, too, you can really feel the difference in friction and bind. I tried the first bearing dry, took a hell of a lot of torque to move it a little. Greased the tool, way better.
It's a lot easier when you have a tire changer to hold the wheel steady, too.
I've had trail bike bearings under water with none getting in the bearing. I've found pressure washed bearings with sand in them - they not only force water past the seals, but grit, too. I wouldn't even hit them direct with a garden hose spray. Those seals are just flexible plastic, doesn't take a lot of pressure to unseat them, but they handle rain fine.
jo_mama
12-02-2011 06:25 AM
