ABS Brake Recall
#141
Thats exactly what you had on your car. Only half of your master had a problem so you were down to one of the two braking systems. Go back to 1966 on a car where you had a single braking system, talk about screwed if you popped a flex hose because we all know the emergency brake was seized years prior.
#142
Alarmdoug
I really hope you do not take this with any inflection other than am very interested in learning more about your failure.
What year was your V-Star
Did it have ABS
What exactly failed in the brakes
The reason I ask is that if the ABS failed, as in froze up, then any other motorcycle can have the same concern as the Harley owners. A system did not fail in a safe manner. I would like to see the inside of the V-Star design.
If something failed other than the ABS module due to moisture in the brake fluid, should all of us start inspection other parts of the brake system on any bike. The diagnosis would help everyone.
I kind of learned a different way about moisture in brake fluid. I mountain bike and the hydraulic disk brakes use DOT 4. The second year I owned the bike, first ride of the season, the front brake system started dragging on a long ride and eventually would not release. I did not realize that you have to bleed the brakes and replace the fluid every spring. These brake systems are very small, having only a few CCs of fluid and no reservoir, just a plunger pushing the fluid. Moisture expanded the fluid over the winter and the heat generated while braking expanded the fluid, clamping down on the rotor.
Did it have ABS
N0 ABS
Issue was complete loss of rear brake. Petal went right to the metal. (no pun)
(my own calculation based on other people in the Vstar forums experience)
Old break fluids becomes laden with moisture. Brake fluid absorbs moisture and must be changed.
Motorcycles have naturally very limited amount of fluid to absorb that moisture as the system is so small.
Wife and I, mountain roads, much of the day, heading back to motel on a large mountain, using rear brake at times to stablize the bike going through the curves/twisties (always in mind we dont want to use brakes too often)
Make it to top of mountain, start descending, first curve, rear brake petal goes all the way down, in disbelief, I try again, all the way down, no brake, front still working, NO place at all to pull off and so steep, even if there was, not sure I would have the stopping power or not.
5,10 minutes seemed like eternity, trying to balance engine braking and front brakes to keep the bike up and my wife on the back alive.
Also note at the time, I had no idea what was going on and if the front brake would go out, if it did I knew I was screwed.
Bottom line, once at the bottom, maybe 10 minutes later, rear brake started working again.
Reason, based on vstar forums from our hotel room and I agreed.
Brake fluid was never changed, laden with moisture the fluid got hot on that day and the moisture in the fluid boiled/turned into water vapor creating vapor lock, once the fluid cooled down, vapor absorbed back into fluid and brakes started working again.
I rode home from the mountains, issue didnt repeat and as soon as I got home, checked the manual and required 2 year change was buried in the manual, changed the fluid, fluid came out black, new fluid was crystal clear. never had another brake issue with the bike.
This can happen on ANY bike and why they all call for a 2 year replacement of the fluid. Also, its to the owners benefit in another way, keep the fluid changed/mositure out of the system and you wont have issues with bad calipers/master cylinders etc.
(this is a direct answer to your question, not the issue with the HD ABS recall)
IT IS STUPID THAT MOTORCYCLE MANUFACTURERS DO NOT BOLD TYPE THIS FLUID CHANGE REQUIREMENT IN BOLD TYPE AT THE TOP OF THE MAINTENANCE SCHEDULE.
#145
I started a thread here
https://www.hdforums.com/forum/frame...l#post17218352
Post 10 will sum it up for now. I went in for the ABS recall on 3-11-18 with working ABS and no problems; 45 minutes later I had no ABS, the day before I left for Daytona. I went anyway and post 10 covers what happened after that. Spoiler alert, the DT-II connection apparently caused a failure in the electronic control unit. Harley wants me to pay for it.
I filed complaints with HD Customer Care, NHTSA and the Ohio Atty General's office this morning. I only mention this for those that have working ABS and are considering having the recall done. Had I known I was going down this rabbit hole, I would have thrown the recall notice in the trash.
Dynamick (03-27-2018)
#146
FYI - All producers of DOT 3-4-5.1 glycol based brake fluid recommend changing the fluid every two years and have done so for decades.
The difference in the DOT ratings is the higher the number the less initial moisture in the system.
DOT 5 is a silicone based fluid. Never used it so I never read the label on the container. I change the 05 and earlier bikes to DOT 4 because it is at Walmart and cheaper. But the main reason is to only have one type on the shelf so I don't make a mistake and grab the wrong one which I am capable of doing.
For the few that thought H-D should have done it when the bike came in for a periodic service. No dealer can do a service without an express request from the owner. If they do it is consumer fraud. So If you take the bike in for the 15K service and tell the service writer that. They can only do the 15K. They do not know for the most part when a two year interval comes into play or that it was or was not done. They are not mind readers.
Some try to portray that they are victims when the reality is they are negligent. Man up and as Elvis said "TCB". Take care of business.
#147
#148
I agree with your comment except that dealerships have the capability of testing the contamination levels of brake fluid. In our shop, we open and test all master cylinders during a full service. Then we report our findings to the customer and they decide to opt for a brake flush.
#149
It's hilarious to me how easily (willfully?) some of you avoid or misconstrue the real issues at hand.
1) ABS systems should ALWAYS fail "safe", regardless of ANYTHING, including an owner's failure to have fluids flushed. For an ABS system to fail in such a manner as to disable your brakes entirely,leaving you with no control of your vehicle, is pure criminal negligence IMO.
2) Harley to at least some extent created this entire fluid flush problem by making it impossible to fully flush the brake fluid at home. Lots of owners would rather have the bike sit rather than take it to the dealer shop. Basically H-D tries to hold our bikes hostage for service by locking us out of basic maintenance ability.
#150
In my opinion its not a design flaw in the HCU otherwise there would be a recall, the valves aren't sticking and blocking a port, its not mechanically failing, its getting plugged with contaminated fluid due to lack of maintenance and there's no fail-safe that can account for that.
The cause invariably seems to be the 1st valve sticking. Could it be sticking from contaminated fluid? Yes. Be it sludge or corrosion. Should this valve fail in the closed position? No.
Other manufacturers abs failures result in a skid, while Harley's results in brake loss. While you might not see that as a flaw or a problem, others do not share your opinion.
As for recalls, there's many out there that should be recalled, but aren't. The Goodyear G159 tire, BMW 1200 front forks, BMW front brake line, Volvo P2 gas tanks, as just a few examples of recalls that should have happened, but haven't.
