Best Fork Springs For ElectraGlide?
Would like to replace stock springs with something better. 2007 Ultra. Opinions from those that have upgraded their fork springs is greatly appreciated. Fork oil weight is a plus. Looking for a smoother ride with no rebound. Now on some bumps the front end rebounds to the top. Causing a bang.Thanks. OLD 96.
XRX (09-08-2018)
Fork Springs
I went with Race Tech springs, and their full front end kit in my 012 Ultra. Made a big improvement over stock. Big gain for a reasonable outlay of money. Made in the USA not China. If you have the funds for a cartridg type look at Traxion or call Howard for his advise on the Olins kit he offers.
Stock springs on the 07s suck but the valving ain't too bad. Depending on your weight, I would go with progressive std springs or 1.0 to 1.1 kg/mm straight wound springs. You can drill the center bleed hole out to 7/64" and use 5 wt oil. IMO this works as good as Racetech emulators and don't cost that much. Ohins are probably pretty nice but cost 8 times the springs / valving change.
ratpick (09-09-2018)
