07 Electra glide brake fluid dot 4 or 5?
07-06-2018, 07:51 PM
Replacing my rear tire and brake pads gonna drain and flush rear master cylinder. HD manual says 4 reservoir says 5! Who do I believe???
07-06-2018, 09:40 PM
sounds like someone put the wrong cap on your reservoir.....my 05 E glide was dot 4.
07-06-2018, 10:02 PM
Spoon test. Take a plastic spoon full out of the reservoir, then add a drop of what you think it is. If they mix they are the same.
07-06-2018, 10:31 PM
Someone has changed your cap. This is off my 07 and I've owned it since new. Just flushed mine and refilled with DOT 4
07-06-2018, 10:33 PM
DOT 4 is what is in the Service Manual.
07-07-2018, 05:17 AM
If it is DOT5 it starts out blue/violet when fresh out of the bottle, but turns yellow over time. So the suggested spoon test above has a backup check!
07-07-2018, 09:11 AM
My 07 Ultra has DOT 4 on both caps.
rjgordon0
07-19-2017 11:35 AM
freebyrd
07-04-2017 06:14 AM
Napalm Dog
07-20-2012 07:15 AM
tom lipke
01-07-2012 12:04 PM
tspierce
Wheels/Tires
04-29-2010 10:15 AM
