Bike won’t start
I could use some help or advice if anybody has some. My 06 fuel injected streetglide won’t start. I had no spark so I figured it was the coil and replaced it. Still no spark. I upgraded the plugs and wires at this time as well so it’s just not getting any power to the coil. Switch works, motor cranks, every once in a while it’ll fire and die. I’ve been thinking cam sensor or maybe a relay which I’ll start looking into tomorrow night. Plenty of oil, not sure if it has a low pressure sensor or not. Not sure where else to look, anyone else have anything thoughts? Thanks in advance!
Why not pull DTC Codes as opposed to just changing parts?
https://www.hdforums.com/forum/sport...des-dtc-s.html
What is the battery voltage?
To run you need fuel, air and spark.
Do you hear the fuel pump?
Do you have spark?
Once you narrow down what to look for it's easier to fix.
Throwing parts can eventually fix it but is kinda expensive...
Do you have spark?
