2018 M8 upgrades
Just bought a 2018 road glide special, definitely doing the stage one upgrade. Contemplating stage two on the torque cam, would appreciate input before I pull the trigger.
Thanks in advance.
Thanks in advance.
No specific advise other than to use all HD/SE parts if you want to protect your power train warranty.
And be careful because apparently some HD dealers are installing non EPA compliant parts and telling people it will be ok.
I have a 2017 Limited with a stage one upgrade.
V&H FP3 Fuel Pack
Rinehart MotoPro 45 slip on's without headers
K&N air cleaner using the OEM housing with a custom cutout (saw this on YouTube) for a second screen to increase air intake volume.
There is plenty of pull with two up and overnight gear on tour pack. The sound is throaty and growls between shifts and has the distinct harley sound. This sounds great to me ( i realize this is subjective) under idle, light throttle, hard throttle and at cruise speeds. This setup does not produce the deep hollow sound that my friends 2017 limited with the Rinehart 4" pipes with headers has. I can hear his bike 1/2 mile away. I lead when we ride so I can listen to my music.
This self installed setup cost me $1,000. I would do again.
V&H FP3 Fuel Pack
On my 2018 Road King I did a Stage 1 (SE tuner and A/C) with Two Brothers Racing Slip-Ons, sold to me by the Dealer. I am 100% pleased with the result. Great sound and performance.
I did stage one and two. The set up is listed on my signature. The tourque cam does just what it says. Tons of extra tourque down low. That makes it popular. Who wouldn’t want that? Gears 1-5, just a flick of the wrist, big roar from the pipes, and lots of pull. On the highway in sixth it leaves a little on the table in my opinion. Takes a little more wrist or a downshift at the higher speeds and gear. I guess that’s what the power cam is for? I don’t know. You don’t get to test ride them. All I know is I love the way it runs with the tourque cam, and I feel like it was worth it.
You may also want to visit the M8 section as well. There's a lot of guys that have posted threads about this very topic.......
..... why do you want to modify your motor ? higher top speed ? make more noise ? pull better under a load ? run cooler ?
...There are lotsa options to accomplish the above goals, but'cha need to 'know your why' 1st
....... i'd just ride it for a while & figure out what exactly you want out of yer mods
Since there seem to be some issues with the M8, I stuck with all H-D parts including the SE tuner and had the work done in my first 60 days of ownership so that the performance parts would be subject to the factory warranty also. A possible majority on this forum feel that any non Harley tuner and header pipes is going to void your power train warranty and I am in that camp also. You will lose some performance by sticking with H-D parts but if warranty is important it could be worthwhile to make that sacrifice.
IndianaHarvey
2014-2024 Touring Models
May 23, 2014 10:14 AM
