RAM mount options for GPS?
Old Jul 2, 2007 | 02:23 PM
shekmark's Avatar
shekmark
Default RE: RAM mount options for GPS?
Where do you connect those two wires to hard wire the GPS? Should I have my dealer do it? Mark
1998 RKC
2007 CVO Springer
Old Jul 2, 2007 | 02:30 PM
gman's Avatar
gman
I just tied them into my cigarette lighter under the fairing on my UC. ain't a big deal to do.
[IMG]local://upfiles/12616/114378A4103346CE8E4F050D94B2D75D.jpg[/IMG]
Old Jul 2, 2007 | 04:39 PM
TRUBRIT's Avatar
TRUBRIT
I mounted the clamp on the vertical part of the bar down towards the riser. The 3" Ram bar is almost vertical. This keeps the GPS close to the dash and protected by the windshield.
[IMG]local://upfiles/26561/97E6910F080E45DEA818222370C38FF3.jpg[/IMG]
[IMG]local://upfiles/26561/172174918B7D417899F0F0C9129C2187.jpg[/IMG]
Old Jul 3, 2007 | 06:51 AM
robbitybob's Avatar
robbitybob
Thanks again for everyone's help. I ordered parts to install the Garmin 2610 ($200 from here http://www.edgegps.com/eCart/viewIte...?idProduct=263) on my right brake bracket using a 3" R-A-M arm to the Garmin mount with wiring so I can power it and plug in the aux. audio.
In some ways I feel stupid getting a GPS. But Mama just can't read a map and I can't remember all the turns!I'm hopingthis will make our trips more stress free.
Old Jul 3, 2007 | 08:38 AM
nightglide's Avatar
nightglide
ORIGINAL: robbitybob
No way these GPS rock! hadn't had it long and think damn I was missing out for years.
Old Jul 3, 2007 | 08:59 AM
Uncle Fester's Avatar
Uncle Fester
nightglide, how did you mount your GPS? I've got my Zumo on the bars for the moment, but I'd really like to mount it more at eye-level at the top of the fairing like you have. It shouldn't be a problem to bolt the diamond-shaped RAM 2-hole base to the "shelf" above the tach/speedo, but my big hangup about that is routing the power and XM antenna cables. I want to run them into the fairing to keep things looking cleaned up, but that would require drilling holes for the cables through the top of the fairing, and I'm concerned about water getting in there on rainy days/wash days.
Old Jul 3, 2007 | 09:23 AM
TRUBRIT's Avatar
TRUBRIT
I found the GPS an advantage when I was riding up in the Smokies recently. I had it set at 500 ft so I could see the curves I was coming up to. I was not caught out by any decreasing radius turns or hairpins. I did not attempt to use this on The Dragon however.
Old Jul 3, 2007 | 10:04 AM
hartick's Avatar
hartick
ORIGINAL: TRUBRIT
took a ride up to lake placid last weekend. set the map out far enough to see the curves before i was in them.
i am definitly able to read a map and find my way, but i dont want to run out of gas on my long trips. plus i have downloaded most all the microbrews in the states. and harley dealers.
Sailing Rider
Sep 19, 2022 06:27 AM
Londonbike
2014-2024 Touring Models
May 24, 2015 11:09 PM
RATROD HOG
Apr 13, 2009 01:55 PM
wrenchguy24
Sep 27, 2008 07:13 PM
beaucoup_dinkydow
May 14, 2008 08:20 PM
