Solid Compensator
Old Nov 13, 2018 | 08:07 AM
Torpedo1's Avatar
Torpedo1
Originally Posted by Kingglide549
If this is true, not arguing here, as IDK,
BUT if it is true -
The crank is a POS
For at it's worth, I asked that question to the mechanic and he said no way, and he's never seen an issue in any they installed between two shops.
The argument that because the compensator fails it must be doing its job seems moot if they are already on like their 5th revision...
Old Nov 13, 2018 | 09:18 AM
TwiZted Biker's Avatar
TwiZted Biker
Was the guy an actual mechanic or the usual parts swapper that passes for a mechanic today? There is a difference and if you understood the physics behind what a compensator does, the ratio's involved and the lame crank's harley uses it wouldn't be a point of contention. A solid comp sprocket is going to hammer the crank and trans bearings, it's when something will fail not if . All depends on the rider, the bike and riding style.
Funny thing is when the gearing ratio was lower in the primaries you never heard of a comp going bad, get your head around that........
Old Nov 13, 2018 | 09:23 AM
Kingglide549's Avatar
Kingglide549
All i can say is
NO from an engineering point of view-
absolutely NOT!
Should a crank come apart from the initial loading ...UNLESS it was constant abuse dropping the clutch at 60000 RPM maybe they woud have an excuse.
Maybe.
IF this is the case that HD needs a shock absorber in the crank drive train......I would say it is a rubber crankshaft and get rid of it.
The crank and flywheels are designed to absorb the shock, load and pwr pulses.
That is what they do as in any crankshft
Old Nov 13, 2018 | 09:57 AM
cwsharp's Avatar
cwsharp
No worries, as per usual all the exp here will come from those that have no exp with going to just a sprocket.
They will repeat the internet chatter and their fingers will just be poping the words.
From an engineering point of view with lots f numbers and stufffff.-
It comes dwn to two things
Power pulses, and low-speed absorptions.
(RPM divided two) broken dwn onto seconds if you want.
No matter what you do you have just two cylinders made to fire unevenly.
Almost end of subject.!
But for Now-
To get rid of the power stroke shock pulse Hd has used many types of comps.
Replacing them with just a sprocket has been a go-to for years and works well.
I know of no one that has broken anythng ever.
Shifting would be unchanged as the clutch is still the same and matching the dwn shift is all the same
.All that happened is now the engine is a little more direct tp the transmission.
Go for it and tell us how it goes.
I think you will like it a lot, and HD will miss out selling you a 600 dollar part again and again.
Good points! I would imagine, however, that you have to consider what you use the bike for. By hard shifts I mean stress on the components and if you ride long distances without shifting much because your bike is on a trailer then I would doubt that a 'solid' compensator would make much difference. Banging gears all over town might be different. I can't say by proof of statistics and I doubt that anyone can. I just think that even though the clutch naturally slips to reduce the impact of a shift I have my doubts that this is equal to a compensator that 'eases' into compensating. If HD thought this was a bad idea and that a solid compensator would be better then why haven't they given up with all of the design changes that they have done and just used a compensator eliminator? What do the M8's have? Aren't they balanced engines?
Old Nov 13, 2018 | 11:49 AM
Kingglide549
Look at it all this way
Most engines do not have compensators at all.!
In fact, I can't think of any until the dual mass flywheels came along and they did not work out so well
Old Nov 13, 2018 | 01:10 PM
Keithhu's Avatar
Keithhu
Most engines arent 45 degree V-Twins either
Old Nov 13, 2018 | 03:13 PM
Kingglide549
It does not matter-
There are single cylinder diesel in the world, two cylinders,
three cylinders that put out a hell of a lot more TQ then HD can dream of.
The number does not matter it is the power pulses.
Like I said, i know of no such crank failure in an HD, as screwed up as they are.
The twinks get out of phase from the get go.
Not sure what the M8 will do.
But again -if deleting the rubber biscuit on the crank and going to just a sprocket
destroys a crank-they did not have much of one to start with.
Old Nov 13, 2018 | 04:02 PM
HD Bobber's Avatar
HD Bobber
Read in the engine section that the M8 cranks are just as out of wack as all others.
Old Nov 13, 2018 | 04:36 PM
Kingglide549
Probably the best thing a Twink owner can do is a crank weld job and call it done.
This will take care of most all the other problems.
It is a big wonder of wonders that HD does not have a "Stage kit " for this.
Old Nov 13, 2018 | 05:01 PM
Keithhu's Avatar
Keithhu
Even with the pressed process, its pretty damn rare to have crank problems, I think people spend a lot of money trying to prevent/fix problems that would never occur.
