Stereo issues on 2016 roadglide ultra
check your audio configuration, it is possible that you have nav or comm prompt on headset while music is on speakers. Even if you don’t use a headset the system will turn down music when nav prompt or phone calls are received
Austin10 (03-14-2019)
The volume settings on each function is separate. The radio/music volume is unrelated to nav, phone or comm volume.
If listening to the radio and you get a phone call, with ring volume turned low/off, it will interrupt the radio without sound. Same goes for a nav route running in the background. If the volume for nav prompts are low/off, the silent prompt will interrupt the radio.
Check all of the volume settings individually and see where you land.
Having the same issue. Audio is fine until you start rolling down the road.
Doesn't matter if you're using Bluetooth or FM.
I am wondering if it's related to the speed sensor
M R (05-26-2019)
True.... mine did the same thing (2019 RG).... I had my nav route volume (the lady that talks to you) muted or turned way down so every time she had something to say my speakers would cut out - I wouldn't hear her voice, but my tunes muted never the less. Turn that Nav route notification off and the problem will go away.
Edit - If you don't have an active nav route set all will be good... you will never hear the interuption.... it's not until you set a nav route that she will start barking out directions and muting your tunes.
