Battery not charging properly - Intermittent
Old 04-16-2019, 05:41 PM
09fitz's Avatar
09fitz
09fitz is offline
Originally Posted by bufbills
As said above, 12s have the voltage regulator issue. Ask me how I know.
Mine's a 2012. Same problem.
Old 04-16-2019, 06:17 PM
Zerk's Avatar
Zerk
Zerk is offline
Volt vegs have historically been a problem for Harley.
Old 04-23-2019, 04:37 PM
CalgaryBikeBum's Avatar
CalgaryBikeBum
CalgaryBikeBum is offline
Just came across this post and will add something if the regulator wasn't issue. My 2011 drove me nuts trying to find problem. Then one day I noticed the harness that comes from the battery to the voltage regulator had two encapsulated wires in the plug. The postive one had come loose so when you pushed them together it only pushed the wire back and didn't mate with the regulator correctly. So seemed ok for a awhile then you hit a bump or turn on one to many things and it would start not charging. I went to HD dealer to buy the connector and they had 7 in stock. A sure sign that they were an issue. Either way after changing it there were no more problems for the last year so I"m sure that was issue.
oldhippie (10-09-2019)
Old 10-09-2019, 09:06 AM
Dwain Buchanan's Avatar
Dwain Buchanan
Dwain Buchanan is offline
Stage III
Default Voltage regulator
Was reading post and wondering if my battery terminals/connectors are loose.my lights where dimming a couple times the other night and when it warms up,it misses and pops at times on take offs,i thought was bad gas but someone said voltage regulator,seeing i got 2012 sportster,i might fall in category,my question is do i buy from HD or outside sources
Old 10-09-2019, 01:44 PM
Zerk's Avatar
Zerk
Zerk is offline
It happens more than you would think.
Will-N-Missouri
08-26-2023 08:38 PM
Stromhammar
12-21-2022 07:57 PM
Tomcatx5
Electrical/Lighting/Alarm
10-04-2015 07:23 AM
70mach1
08-29-2007 06:16 AM
rsnky
10-22-2006 06:09 PM
Quick Reply: Battery not charging properly - Intermittent
