Brakes go soft when engine is running
You likely bent the rotor when the wheel was off for the tire change. You can pump up the brakes and they will hold tight until the bent rotor turns and pushes the pads apart slightly. Press the pedal and you can close the pads again but the rotation of the bent rotor will push them back out as you ride.You might be surprised how little it takes to cause this problem.
The issue was solved in 2020. Paul, a new member was simply giving his appreciation after clearly using the search function. You're answering something that has been solved for two years.
