Cam install and backfiring
2007 FLHX (96 twin cam) S&S 551 cam install with S&S Quickee adjustable pushrods. After install bike started right up, sounded ok but a bit rough. Went for a 1/2 mile test ride. Bike started running worse, massive backfiring, through intake mainly. Bike stalled out, it will still turn over but even backfires while trying to start, however, it won’t start. Triple checked my timing with install did pushrods by the book and feel that it’s gotta be something else. Why would it start initially after the install, start backfiring and running like crap and now not start at all? Pushrod adjustment issue? Cam position sensor?
This is exactly why I go to the dealer. (And typically take flack on here)
Have them do the work and when I pick it up it is running fine or they fix it right
If you were running it on the stock tune, it was running excessively lean. Hopefully you didn't run it long enough to cause any damage. If you did have a decent updated tune for the cam, you very well could have the cam timing off, or, push rods not adjusted correctly. It could be off on cam to crank timing, or, cam to cam timing.
