install wrapped front fender
Hi i’m Mark from the Netherlands Amsterdam
Im busy with building a bagger and need some advise on how to mount the new fender
I have to drill holes in the fender but what is the best way to do this
can somebody please advise me on how to figure out where i have to drill
I first put in the wheel and ad some rope between the and wheel for the clearance
many thanks
many thanks
thank you so much for the reply
but the mounting holes are closed on the other side
thats why I have the problem for drilling the fender correct
Get yourself a marking pencil, put some masking tape on your fender mounts, place your fender where you want it, then trace the outside of your fork mounts onto your fender mounts. Remove your fender. Then get yourself a piece of paper and hold that up to your fork mounts, trace your fork mounts out onto the paper and also mark the bolt holes trough the paper. Then place the paper onto your fender mounts as a template and line up the mount lines with the mount lines on your fender and then you will see where the holes need to be drilled.
Before you drill , take a measurement of centre of one hole to the other and double check and make sure you have your holes at the right space apart. you can also drill your holes one size up from the size of your bolts just to give you a little to play with.
Bruce
Bruce
mark16w (01-25-2020)
Hogpro
09-20-2012 12:02 PM
