Parts list for slider change
Planning to pick up chrome sliders soon and an having trouble finding any solid info on what I should be changing while it's apart as far as seals/bushings. Is there a kit of parts or a list of needed items?
Not going whole hog with big dollar parts, but is there a worthwhile cheapish upgrade to do? Intiminators?
Sliders I bought a James gasket and seal kit from dennis kirk. and used 15 weight fork oil to stiffen it up a little. I painted inner fairing and did bars and riser bushings when I had mine apart. don't forget to get the chrome cowbells.
also good time to polish the front wheel and check brakes and bearings
The following 2 users liked this post by lp:
Campy Roadie (04-16-2020),
ratpick (04-15-2020)
caulk04 (04-16-2020)
I just did chrome sliders on my 2012 RG and this is the kit I used, James Gasket and got it from Ebay for less that $20 shipped. Worked perfect. My bushings were in good shape as the bike only has 13k miles so I didn't change them.
https://www.ebay.com/itm/James-Gaske...72.m2749.l2649
If you need the bushings also this kit has everything except O-Rings
https://www.ebay.com/itm/HardDrive-F...MAAOSwYnlcyRol
This is a little time consuming but not a hard job. plus I made the tool to tap the top seal in, out of a 2 inch pvc coupling, just ground down the edge little at a time til it fit. I watched video on you tube and all went well. You will love the chrome lowers, so much easier to keep clean and look way better.
