clutch issues
Old Jul 31, 2007 | 01:50 PM
2002bigbored's Avatar
2002bigbored
Default clutch issues
the other day was on a run, and when i went to pull out from a light my clutch did not engage! so i pulled it back in and let it out again and it worked. the lever is real tight, hurts my left hand while riding in the city. seems like it engages almost all the way out. im not mechanically inclined when it comes to clutches and adjustments or lubing but is mine shot or just needing lubing and adjustment? how long does ones clutch last?
Old Jul 31, 2007 | 01:55 PM
Neckball's Avatar
Neckball
Default RE: clutch issues
Sounds like it's time for a lube job for the clutch cable .. Pretty simple job, get a service manual and teach yourself.
Old Jul 31, 2007 | 01:57 PM
Kahuna's Avatar
Kahuna
If your bike is brand new, the clutch will get easier over several oil changes. If your bike has more than 40k miles, it might be time to have the clutches inspected for wear.
ORIGINAL: 2002bigbored
Old Jul 31, 2007 | 02:00 PM
2002bigbored
bike has just over 20k on it.
Old Jul 31, 2007 | 02:15 PM
azhole's Avatar
azhole
I'm no harley mechanic, but it sounds like the cable is binding somewhere. I'd lube the cable, and check for a sharp enough bend in the cable to where it would bind. Have your cables been re-routed for some kind of modification? If so that's the first place I'd look.
I'd try those two things first, then I, myself, would crack the primary case and see if the basket is moving properly when the clutch cable is pulled.
You might just take the time to find a service tech, not necessarily harley dealer, and have him lube and adjust the clutch, since you say you're not mechanically inclined. It's all in what you're comfortable with.
I watch what the tech does when I take it in, and ask questions and learn what's up. I use a trained tech, but he doesn't work for HD. He works for a local shop and has been very good, and very, very cool about showing me while he works. Just don't expect him to take more than a minute or two to outside of his schedule to talk,though he might. My tech tells me as he goes along, and the last time I replaced my primary chain, anchor plate bolt fell into it and destroyed it, I did it all with just the manual, and a few tips from my non-tech cousing that paid a tech to teach him to do it. Really simple if you have the proper tools! (at least that job was)
Old Jul 31, 2007 | 03:51 PM
2002bigbored
have an appt. to have it lubed and adjusted.
higbee76
Jul 23, 2017 02:55 PM
ElectraJim
Mar 30, 2017 09:16 AM
16VAFXDL
May 24, 2011 08:07 AM
kmealp
Apr 5, 2010 06:02 PM
Lightngsvt2
Jun 20, 2009 05:52 PM
