Audio Output from stock Harley Radio
Old 08-01-2007, 06:44 PM
cglofland's Avatar
cglofland
cglofland is offline
Default Audio Output from stock Harley Radio
I have a 07 Road Glide and my wife and use Nady MRC-11X radios for bike-to-bike comms on trips. Would be nice if I could output my audio system from the Road glide into the Nady. the nady has a input plug, the stock radio has a audio in but no audio out. Anyone help?????
Old 08-01-2007, 07:39 PM
sped's Avatar
sped
sped is offline
Default RE: Audio Output from stock Harley Radio
I'd be interested to hear about this also if someone has a solution.
Old 08-01-2007, 07:56 PM
cglofland's Avatar
cglofland
I purchsed the touring electrical manual today and may venure into the bowels of the radio this weekend. Got to be a way to get an audio out line, even if it is the output used for helmet hookups.
Old 08-01-2007, 08:37 PM
sped's Avatar
sped
sped is offline
ORIGINAL: cglofland
A buddy and I were considering exploring the speaker switch as a posibility of directing the output either through the speakers, or a headset plug of some type. I'll be keeping an eye on this thread. Thanks!
Old 08-01-2007, 08:38 PM
choochoo's Avatar
choochoo
choochoo is offline
No but you can do this if you want.
Gain access to the forward speaker wires.
splice into them and buy a female speaker jack
that can be mounted to the inner fairing (like the lighter
socket is). Solder the wires to it in the proper manner for
a stereo system.
It will work, (but no guarantees on the output or harm to the amplifier circuit) but the better way is the way a home stereo does it.
when you plug a headphone into it, it interrupts power to the speakers.
That requires a different type of plug. But radio shack sells it too.
So your other option is the wires for the ultra setup with the headset
pod (on tank), this is an output signal. I'm not intimately familar with the HD wire setup on this plug, perhaps the electrical manual will help there.
If it is a standard stereo plug, thenyou can buy a plug adapter (reducer) from Radio Shack.
I hit the submit button too soon.
Old 08-01-2007, 09:20 PM
Tech2's Avatar
Tech2
Tech2 is offline
ORIGINAL: choochoo
a stereo system.
I'm not sure this will work. The problem is the impedance of the speakers vs the impedance of the headphones/headset. Again, I'm not 100% sure, but I think there's more to a headphone jack than just routing a parallel circuit with the speakers off of the amplifier output.
Old 08-01-2007, 09:26 PM
sped's Avatar
sped
sped is offline
ORIGINAL: Tech2
That's my understanding also. I'm nowhere near anyone with any mechanical or electical espertise, but for someone who has, it would seem easy to route sound through the speaker switch on my Road Glide.
Again, I'm trying to work my way up to "amateur" status.
Old 08-01-2007, 09:52 PM
cglofland's Avatar
cglofland
The schematic for the road glide shows the spk switch having input from the headset out A & B. Three positon switch but connections to only 4 pins. Still thinking this over.
Old 08-01-2007, 09:57 PM
cglofland's Avatar
cglofland
Later tonight I'll post the pin out on the plug from the radio if someone wants to get exploring.
Old 08-01-2007, 10:29 PM
gbglider123's Avatar
gbglider123
gbglider123 is offline
Hi guys. I'm just starting to research an almost identical situation. Just purchased an Autocom Super Pro AVi system for my '06 EG Classic, and am looking to rig a headset-out jack to pipe audio from the HK radio into the Autocom unit. Thought about taking signal directly from the fairing speaker leads into adash-mountedjack, but not sure about the output level or a possible impedance mismatch. I'm also trying to determine if my base radio is the same as the Ultra, which has pin-outs for headset speakers. I know my radio chassis has the pins (connector 28-a in the schematic), but don't know if they're active on my Classic radio.
I'll keep seeking answers and will post if I make any headway.
I wonder if JMJOHN would weigh in on this...he has a teriffic rep on this forum, and I'd bet he know! Btw, I'm thinking about upgrading my fairing speakers with the J & M replacements at the same time.
Brian
Quick Reply: Audio Output from stock Harley Radio
