Replacing starter
Old Aug 3, 2007 | 09:24 PM
rsherrow37's Avatar
rsherrow37
1st Gear
Default Replacing starter
Just came offnice day trip thru N. Ga. mountains (500 miles) and we stopped quite a bit during the day and notice my starter kinda skipping/grinding, went to start it up and hour ago and it just spins, any suggestions, is this something I can replace myself, it certainly seems easy enough to access and I really don't feel like waiting 2 or 3 wks for the local dealership to work it in. Thanks for any help/suggestions.
Old Aug 4, 2007 | 01:17 PM
BK Meyers's Avatar
BK Meyers
Default RE: Replacing starter
What kind of bike do you have?? I recently had to change the starter on my Road King. Not a huge deal but I ran into some complications with removing the old starter (the chrome cover on the end created just enough length to wedge the starter very firmly into place). On the Road King the primary cover has to be removed to access the starter jackshaft bolt, so be sure to pick up a quart of primary lube and the necessary gaskets. Try finding the aftermarket gaskets that have the "printo-seal" type face on them, as they can be reused and are generally less expensive than the stock HD paper gasket.
Also, check out the high torque units offered by Ultima. I picked up a 1.4kw in full chrome for $150 shipped. HD wanted $320.00 plus tax for a stock piece.
Later,
BK
Old Aug 4, 2007 | 02:30 PM
DeJavu's Avatar
DeJavu
As a quick trouble shoot, short the solenoid terminals with a plastic handle screwdriver. If it doesn't engage you can save time and expense by just replacing it. I'm not sure how well this works on newer bikes.
Old Aug 4, 2007 | 09:32 PM
GREGALT12's Avatar
GREGALT12
4th Gear
sounds like the starter clutch I have put a lot off clutch's in Harley starters[/align]
Old Aug 5, 2007 | 07:46 AM
04RoadKing's Avatar
04RoadKing
Yeah it kinda souds like the starter clutch is going bad. Mine shot craps last year. It was acting up for a few days and then it just stoped working. Get your self a service manual and it's pretty easy. It took me around 2 hours but that was my first time. I bett I could save off 20-30min if I had to do it again. Oh by the way the starter clutch only cost me $50.00 from a local indy shop.
Old Aug 5, 2007 | 08:19 AM
choochoo's Avatar
choochoo
Yep what BK Meyers said.
Year make and model first!
Different bikes are different.
But since it is mostly nuts and bolts
you ought to be able to figure it out.
But the FIRST tool you need to buy is a "SERVICE MANUAL"
Old Aug 7, 2007 | 01:25 PM
WeeblesWobbles's Avatar
WeeblesWobbles
Stage IV
I currently have the same problem again (97-HDFLSTC). The original starter was replaced with a high torque one and then I replaced that with a rebuilt one last year.
How can I tell if the starter clutch is defective?
Old Jul 14, 2013 | 02:41 PM
rick feran's Avatar
rick feran
Stage I
Default Rick
I replaced my starter on road king starter ingages but stays on fly wheel what up or how do I fix that?
choptop
EVO
52
May 2, 2015 10:06 AM
Earnie1200C
Jul 17, 2012 03:55 PM
98 Heritage N.Indiana
EVO
Feb 21, 2011 10:54 PM
krazedstang
Jul 27, 2009 12:31 PM
02glide
Nov 18, 2006 06:05 PM
