21 Limitied EITMS Issue
Old Jan 24, 2022 | 04:44 PM
Ryan Arterburn's Avatar
Ryan Arterburn
Stage II
Default 21 Limitied EITMS Issue
Greetings everyone. I got a 21 Limited and went to start it up and check engine light is on, go to the infotainment and check what is displayed and it says the EITMS is On. I just installed Tab Zombies Slip ons, Legends and 12" Meathooks. Any ideas before I call Low Country HD? Thanks in advance.
Old Jan 24, 2022 | 04:54 PM
GalvTexGuy's Avatar
GalvTexGuy
EITMS has nothing to do with the check engine light. Pull up the code(s).
Old Jan 24, 2022 | 06:14 PM
kojak's Avatar
kojak
You probably have some sort of wiring issue with installing apes. Like someone said, pull the error codes.
Old Jan 24, 2022 | 07:45 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
I set a code every time I install handle bars. Almost impossible not to. Just pull up the codes, and clear them out. You should be good to go then.
tlminh
Exhaust System Topics
Dec 28, 2015 09:33 PM
Road Star
May 31, 2015 01:42 PM
ronyd
Sep 9, 2007 11:51 AM
cjackson
May 5, 2007 12:30 AM
