Upgrade to Rockford fosgate pmx-hd9813
I just about finished installing my upgrade to this unit when I went to plug in the 2 main wire harnesses from the bike to the head unit. Only problem is that I have 2 24 pin wire harness and not the 35. I suppose I'm gonna have to return this? Or is the a adapter of some sort to make this work?
DW ,, which brand is that replacement radio you used?
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Rockford Fosgate pmx-hd9813.
After investigating online this is what i was told i needed.
1130-72997-01
Which is the 2 connectors for power and rear speakers. Sorry i tried to upload a picture but it wouldnt let me.
1130-72997-01
The only thing coming off of the 35 pin connector is the rear speakers. I think they are pins 1 and 24 for 1 speaker and 2 and 25 for the other. I just put this HU into my '13 Classic. If you are going to use an amp with it, you can use the pre-amp outputs for the rear instead of getting the other plug.
Here is a plug on ebay that will plug into the back of the radio and you would have to splice into your rear speaker wires. It saves a few bucks over the one you mentioned and it is only the 1 plug that you need.
https://www.ebay.com/itm/Harley-Davi...-127632-2357-0
That's the plug that fits the 06-13 Harley oem Harmon Kardon head unit. The Rockford Fosgate is made to plug right in to the stock wiring on those years. If the radio is working for you except for the rear speakers, this is the plug that will get the rear speaker outputs for you. You will just have to find which wires in your plug goes to the rear speakers and splice them to the wires on this plug. My 13 EGC didn't originally have rear speakers so I ran speaker wire to the fairing and hooked them up to the 4 wires in that plug.
