Front Fork Squeak
Old Mar 31, 2022 | 07:52 AM
kentuckytexan's Avatar
kentuckytexan
3rd Gear
Default Front Fork Squeak
At least I think it's the front end squeak. But when off the bike and engine running, there's no squeaking. However, when I sit down onto the bike with the engine running it squeaks. However, the squeaking becomes constant once I start moving. When I come to a stop, if I pull the front brake fairly hard and load up those forks on the stop, the squeaking stops. Once I stop however, and the bike settles, then it starts the intermittent squeaking. I can actually get the forks to squeak, very lightly when the engine is off and I push down hard onto the handlebars to compress the forks.
What do you guys think?
Old Mar 31, 2022 | 08:23 AM
GalvTexGuy's Avatar
GalvTexGuy
Year and model?
Old Mar 31, 2022 | 08:25 AM
kentuckytexan
3rd Gear
2000 Road Glide EFI
Should also say. Guy is from New York, who I bought the bike from last Saturday (of course the bike didn't squeak then!) and it sat a year before he moved to Texas.
Old Mar 31, 2022 | 08:28 AM
GalvTexGuy's Avatar
GalvTexGuy
When’s the last time the forks were rebuilt?
Old Mar 31, 2022 | 08:29 AM
kentuckytexan
3rd Gear
I'm not sure. Probably never. The bike has 30,000 miles on it.
Old Mar 31, 2022 | 08:38 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
Try this, Spray some lubricant on the rubber muffler hangers under the bags.
Old Mar 31, 2022 | 08:42 AM
MyFavRk's Avatar
MyFavRk
Could be your brakes , have you changed pads recently ? Used grease on the back of the pads and some on the pins , vibration can cause those areas to squeak / chatter . There is always a little pressure on the rotors from the pad , even off the brakes , so this could be your issue , worth a check .
Old Mar 31, 2022 | 08:46 AM
702's Avatar
702
Check the front motor mount.
Old Mar 31, 2022 | 09:40 AM
kentuckytexan
3rd Gear
Guy who sold it to me did put new front brakes on, so maybe that could be it. What do you suggest?
Old Mar 31, 2022 | 09:45 AM
kentuckytexan
3rd Gear
Edit: Meant to quote you on this one.
