Normal head temperature
Old Apr 30, 2022 | 11:59 AM
maxxym's Avatar
maxxym
Default Normal head temperature
I use PowerVision with some gauges to monitor things. One of the gauges is Temperature. What I understand is that this is a head temperature, not necessarily oil temp. At times, like today, I saw it go up to 306 degrees in 63 degrees weather.
what would be normal “Head” temp on M8? I think this gauge is causing me little stress every time I see it above 300.
Old Apr 30, 2022 | 12:49 PM
Keithhu's Avatar
Keithhu
If you measure it, you will obsess about it. I often wonder how the 99.99% of riders who never measure head temperature manage to get by without knowing.
I'm pretty sure most would tell you it's perfectly normal.
Old Apr 30, 2022 | 12:53 PM
deadhawg's Avatar
deadhawg
98.6 under the tongue.
Old May 1, 2022 | 06:45 AM
Eastcoast Jim's Avatar
Eastcoast Jim
It's common to see 300 - 350 degrees -- That being said , you can lower it with a proper tune. I rarely see over 250-60 That is in Fla. - sitting at a red light or crossing the State at 85 mph on a summer afternoon . My bike cranks at 210 - high compression
Old May 1, 2022 | 06:53 AM
smitty901's Avatar
smitty901
Ride shut off the temp gauge. No a tune will not lower it to 250
Old May 1, 2022 | 07:25 AM
Eastcoast Jim
That is with a DTT ECM - requires an accurate reading to work properly - The temps are accurate from start up - confirmed with a temp gun - That is on the temp sensor on the front head near to intake - temps are higher at the exhaust @300+
Old May 1, 2022 | 08:06 AM
maxxym's Avatar
maxxym
250-260 in Florida? Man, I don't think I EVER seen temps low like that stay in my PV, no matter what the ambient temp is. I am really not sure how much temperature improvement I would see from getting my bike on a Dyno vs. Fuel Moto tune that I have with some auto tuning.
Are you sure you are not talking about the oil temperature?
Old May 1, 2022 | 08:07 AM
smitty901's Avatar
smitty901
To lower head temps that much you would need a garden hose feeding non stop fuel to it period.
The non wet heads saw 360 in heat and traffic.
Old May 1, 2022 | 08:20 AM
skydude426's Avatar
skydude426
One of the hottest places on the heads is right behind the spark plug. I use a temperature gun and check there after a ride. If it measures under 350 on a really hot day, I'm good with that. Most of the time it’s below 320. The rear head is always hotter.
I run a Thunder Max ECM. The Thunder Max maps use plenty of fuel. I cooled mine down by removing timing. The maps are developed using very good fuel. Not everywhere has top quality fuel. I had to remove timing to eliminate ping and to cool the engine down. Still runs very well.
The ECM gets its head temperature input from the sending unit located on the front head near the intake port. It’s misleading as that is far from being the hottest place on the heads.
Old May 2, 2022 | 10:38 AM
Eastcoast Jim
In response to your comments - I get 250 - 60 head temps like I said - I can go back on the data log & verify- confirmed with an IR laser thermometer - the temp readings show a logical increase- starting out cold under 100 degrees @70 -80-90 - I do have a lot of time in tuning it - 95cu, in 210 - 12 ccp - Woods 6h ,head work, Fueling pump & cam plate , oil cooler on the frame down tube - ecjim
