bad idle with big bore 95 ci kit
Just had my 2001 88ci upgraded to the 95ci big bore kit, with the big bore 203 cams. I have true dual screaming eagle pipes (older type) a screaming eagle air cleaner and a Power Commander. The bike runs GREAT when I am moving at over 30 mph. No complaints there. The problem is with the idle which is real rough and moving at 0-30 mph in traffic. At this low speed the motor seems like it is backfiring and pops like crazy through the pipes. When the dealer did the kit for me (Harley dealer) he told me that he uploaded the screaming eagle map for the motor to my ecm. He did not touch the Power Commander which was mapped for my 88ci engine when I had it installed and dynoed. When I brought the bike back to him, he uploaded a generic map from the Power Commander website to my PC and it runs only a little better. The idle is still real ropugh and the low speed is terrible. Would having the bike put back on the dyno help me out here or am I wasting the 450 bucks to dyno tune it. Is this some type of conflict between the ecm map and the Power Commander map? Should they both be mapped??? I always thought the when I got the Power Commander I did not need to have a map uploaded to my ecm. I am new at this, so bare with me please. What are your thoughts?
RE: bad idle with big bore 95 ci kit
I am sure this is a glass half empty, worst case scenario but...... I had a similar issue and it turned out that the HD mechanic that did the Stage II big bore putthe cams in wrong!!! The cams were installed one spline off of correct. Not enough to keep it from running or to damage any internals but it idled like crap, got terrible gas mileage and the performance was notwhat it should have been.
Best of luck,
RJ
Best of luck,
RJ
